Author Topic: (Version 1.3.4) EBUR 128 - Loudness and Dynamic Range Plugin / Tagging Tool  (Read 41621 times)
BoringName
It's not shown on github but if you use the plugin download link you will see the dependencies folder has a subfolder called "LoudnessTextFiles"
There is nothing in this folder, it's used as temporary storage. If it's missing the plugin will complain. So you just need to create a new folder in the dependencies folder you copied during install and call it "LoudnessTextFiles".
I haven't tested the plugin so no idea if it works but that should solve your current issue.
jan_axhell
Yes! It works now, just like that!  :)
Now I wonder if I can actively use these tags. Does MB consider loudness?
@hiccup I was about to post that I could not find any contact info, but at least this plugin seems to work with just the above workaround.
To contact him, you would probably need to create a github account and then create 'an issue' for that plugin here.
But since BoringName's solution seems to have solved the issue, it's probably not needed anymore.
jan_axhell
I already have a github account, but since his github is parked, it's not possible to open any issue.
