Author Topic: Last builds: no track will be deleted on device during sync  (Read 1491 times)
klint
Hi
For a couple of builds, the tracks that should be deleted from device because they have been removed from synced playlists are not listed by sync preview anymore, and are not deleted by actual sync. Although the right option is checked, of course ("to be deleted with confirmation")
Both for wired and wifi sync.
Am I the only one with this issue?
Thanks
Last Edit: March 18, 2019, 10:53:18 AM by klint
I see its true about the preview, but if you directly did a sync it should have worked.
In any case this fixes the issue with the preview:
klint
Thank you Steven, that was it (I thought i had tested in by syncing one file to be removed actually, but it seems I did not go to the end of the process).
