Author Topic: Menu bar  (Read 1454 times)
PeteJ
It would be nice to be able to auto hide the Menu Bar, as you can with the Windows task bar for example, and also combine the menu bar with the tabs bar, as there seems to be a lot of wasted space up there.
Thinking about it, a similar feature for the bottom panel would be nice as well.
Pete
Last Edit: March 17, 2019, 09:40:03 PM by [email protected]
Not sure about the rest, but you can put the tabs in the menu bar
PeteJ
Thanks, managed to do so.
Pete
