Author Topic: Radio Stream links: share your favorites here!  (Read 63975 times)
The station's server probably requires TLS 1.1/2 authentication, which Windows 7 does not support by default, unlike Windows 10 which is what I have.  To turn it on for Windows 7, copy the following code into a text file, rename the extension *.reg, and run it to put the values into your registry.  Reboot the PC and you should be good to go.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.1\Client]
"DisabledByDefault"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SecurityProviders\SCHANNEL\Protocols\TLS 1.2\Client]
Last Edit: July 20, 2022, 04:09:27 AM by sveakul
Gendji
Still "unable to connect".
I rebooted, checked the reg entries in Registry Editor, just to make sure i did it right, and they are both there.
No idea if it helps in any way, but I tried the FLAC web player from the Soma website and that works.
I don't know man.  From my experience with another player (AIMP), the Windows Media Foundation codecs are in use here vs. the Bass library codecs.  Could be a difference in the Windows 7 vs. 10 version of those, or the stream may be geo-restricted depending on your location.
Does anyone who has Windows 10/11, and the latest version of MusicBee, have a problem connecting to https://hls.somafm.com/hls/groovesalad/FLAC/program.m3u8 ?  Takes about 10 seconds here to buffer before playback starts.
Gendji
Tested the stream in VLC Media Player and that worked, so at least it's not a geo-restriction.
At some point I will need to upgrade to Windows 10 but since I still receive the monthly security updates, it is difficult to say goodbye  :)
  • MB Version: 3.6.8849 P
Connects fine.  Usually about the 10 sec mark to buffer, but have had as long as approx. 25 secs.
But never get the "Artist - Track" info.
make sure you have basshls.dll in the musicbee application folder. Its included in the release package
Gendji
basshls.dll is in the MB directory, version 2.4.3.1.
Seeing that others have no problems connecting using W10/11, W7 must be the "culprit".
Gendji
Updated Digital Impulse playlist.
#EXTM3U
#EXTINF:-1,DI Radio Digital Impulse - Psy Trance
http://orion.shoutca.st:8049/
#EXTINF:-1,DI Radio Digital Impulse - ALYF Recordings
http://orion.shoutca.st:8066/
#EXTINF:-1,DI Radio Digital Impulse - French Skies
http://orion.shoutca.st:8084/
#EXTINF:-1,DI Radio Digital Impulse - Country
http://orion.shoutca.st:8110/
#EXTINF:-1,DI Radio Digital Impulse - Emacore Trance
http://orion.shoutca.st:8114/
#EXTINF:-1,DI Radio Digital Impulse - New Wave '80s
http://orion.shoutca.st:8123/
#EXTINF:-1,DI Radio Digital Impulse - Vocal Trance
http://orion.shoutca.st:8143/
#EXTINF:-1,DI Radio Digital Impulse - Astra Psy Channel
http://orion.shoutca.st:8147/
#EXTINF:-1,DI Radio Digital Impulse - Nature Sounds
http://orion.shoutca.st:8157/
#EXTINF:-1,DI Radio Digital Impulse - Matt Paul Uplifting
http://orion.shoutca.st:8161/
#EXTINF:-1,DI Radio Digital Impulse - Hard Rock & Heavy Metal
http://orion.shoutca.st:8165/
#EXTINF:-1,DI Radio Digital Impulse - Movie Themes
http://orion.shoutca.st:8173/
#EXTINF:-1,DI Radio Digital Impulse - Rik Tights Trance
http://orion.shoutca.st:8177/
#EXTINF:-1,DI Radio Digital Impulse - Ambient Fantasy
http://orion.shoutca.st:8193/
#EXTINF:-1,DI Radio Digital Impulse - Ori Uplift Trance
http://orion.shoutca.st:8223/
#EXTINF:-1,DI Radio Digital Impulse - Asian Trance Festival
http://orion.shoutca.st:8227/
#EXTINF:-1,DI Radio Digital Impulse - Ektoplazm PsyRadio
http://orion.shoutca.st:8231/
#EXTINF:-1,DI Radio Digital Impulse - PMN Mash-Up
http://orion.shoutca.st:8239/
#EXTINF:-1,DI Radio Digital Impulse - DKR TecHouse
http://orion.shoutca.st:8243/
#EXTINF:-1,DI Radio Digital Impulse - Oldies But Goldies
http://orion.shoutca.st:8248/
#EXTINF:-1,DI Radio Digital Impulse - Sonic Oblivion Trance
http://orion.shoutca.st:8364/
#EXTINF:-1,DI Radio Digital Impulse - Toxic Sessions
http://orion.shoutca.st:8379/
#EXTINF:-1,DI Radio Digital Impulse - Gate of Paradise Trance
http://orion.shoutca.st:8405/
#EXTINF:-1,DI Radio Digital Impulse - PowerMixNetwork UNDGND.
http://orion.shoutca.st:8413/
#EXTINF:-1,DI Radio Digital Impulse - ATG Trance
http://orion.shoutca.st:8430/
#EXTINF:-1,DI Radio Digital Impulse - Funk & Electro Swing
http://orion.shoutca.st:8506/
#EXTINF:-1,DI Radio Digital Impulse - Alex Stendor The Space Trace
http://orion.shoutca.st:8554/
#EXTINF:-1,DI Radio Digital Impulse - Liftburg Trance
http://orion.shoutca.st:8635/
#EXTINF:-1,DI Radio Digital Impulse - Best Dance '90s
http://orion.shoutca.st:8643/
#EXTINF:-1,DI Radio Digital Impulse - ATLAS CORPORATION TRANCE
http://orion.shoutca.st:8673/
#EXTINF:-1,DI Radio Digital Impulse - Ahmed Romel
http://orion.shoutca.st:8699/
#EXTINF:-1,DI Radio Digital Impulse - Global Trance Channel
http://orion.shoutca.st:8704/
#EXTINF:-1,DI Radio Digital Impulse - Victor Special Trance
http://orion.shoutca.st:8746/
#EXTINF:-1,DI Radio Digital Impulse - PowerMixNetwork House
http://orion.shoutca.st:8774/
#EXTINF:-1,DI Radio Digital Impulse - Rock Hits
http://orion.shoutca.st:8871/
#EXTINF:-1,DI Radio Digital Impulse - Paradise Trance
http://orion.shoutca.st:8922/
#EXTINF:-1,DI Radio Digital Impulse - Techno
http://orion.shoutca.st:8938/
#EXTINF:-1,DI Radio Digital Impulse - Reggae
http://orion.shoutca.st:8942/
#EXTINF:-1,DI Radio Digital Impulse - Pulsar Recordings Trance
http://orion.shoutca.st:8946/
#EXTINF:-1,DI Radio Digital Impulse - Jazz
http://orion.shoutca.st:8950/
#EXTINF:-1,DI Radio Digital Impulse - Classical
http://orion.shoutca.st:8978/
#EXTINF:-1,DI Radio Digital Impulse - Christmas Channel
http://orion.shoutca.st:8982/
#EXTINF:-1,DI Radio Digital Impulse - House
http://orion.shoutca.st:8986/
#EXTINF:-1,DI Radio Digital Impulse - Blues
http://orion.shoutca.st:8990/
#EXTINF:-1,DI Radio Digital Impulse - Ambient and Chillout
http://orion.shoutca.st:8994/
#EXTINF:-1,DI Radio Digital Impulse - Disco Hits 80s
http://orion.shoutca.st:8998/
Gendji
Took the leap and did an in-place upgrade to W10 Pro. All is working now so W7 was the culprit.
Música
Congratulations!
FWIW, while I do not stream anything through MusicBee, so that I can't evaluate it thus, this great program still runs as fine as ever on both my Windows 7 and 10 installations. My requirements have always been quite basic: I do all CD ripping and collection management, and some listening on W7, and most listening on W10; and, I'm still fully satisfied and thankful to Steven and a bunch of others for their continuing development and support.
Gendji
Congratulations!
Thanks!
The decision to switch to W10 was not MB related for me. It worked great on W7 like you said. The small "issue" i had with SomaFM Flac was not a problem for me.
The actual reason to switch was that ESU ended and the fact that doing an in-place upgrade to W10, has improved a lot over the years. That it also solved the "issue" was a bonus :).
Gendji
#EXTM3U
No idea why but most of these links are not working any more. Most of the streams on the DI Radio Digital Impulse website itself are not working either.
I think they went completely to a sign in/subscriber-based service but did a garbage job cleaning up the current website or explaining any of it.  If you download a .pls, it says "Unable to access account for (playlst name): Invalid username or password."  Even the TuneIn web links pushed on the DI home page come back with "This station is no longer available."  What a way to run a business (if indeed it even is one).
