I've started this topic so MusicBee users have one collective place to post their favorite radio station URLs or even links to exported xml station lists. I personally use MusicBee for streams about 60% of my listening time, and have found it the most well-optioned player to do this by far.
Stream links can be mercurial; they come and go, change URLs, can be difficult to uncover, and even "exit stage left" permanently. Hopefully this will be a good spot for users to ask questions and get answers from MusicBee's contingent of radio fans.
So, have at it, share some favorite genre links, help dig-out direct URLs of web-based players, etc.
Note: When importing stations from a pls/m3u/m3u8 playlist into MusicBee as a MB playlist, stream track metadata (artist/title) will now be shown if the playlist is in #EXTINF:-1 entry format. The format does not apply to using the Radio Station "New Station" method for entering a direct URL. Be sure you are using MusicBee 3.3.7232+ . Stream playlists you had added prior to that version will need to be re-imported for the metadata to show.
Revised October 20, 2109
(thanks to Global Moderators for pinning this topic)
