Author Topic: Can not sync with Galaxy S9  (Read 1262 times)
dferr042
I have tried playing around with the sync settings to no avail, I keep getting the message that the data is invalid or the data supplied is of the wrong type. let me know if you need anything else from me. thanks
MB version?
Wired or WiFi sync?
It might also help if you listed the steps you're taking in order to sync.
And a screenshot of your device settings.
screenshots: https://getmusicbee.com/forum/index.php?topic=3998.msg153348#msg153348
