File-A keywords: Winter; Night Driving
File-B keywords: Winter; College
Say I want to select both files and add keyword "Had A Pizza Delivered But They Forgot The Crust" while also keeping the tags that already existed on each respective file.
Any tips?
My tried and tested method of dealing with this way of cataloguing music tracks, is by using the "Grouping" tag.
For example, "Grouping" could contain [Winter Night Driving Party Chill Bored Pizza] etc. etc. (no : ; or , needed).
Experimentation is worth the effort! There is room in the Grouping tag for about 46 (?) characters, so just enough for your 'Pizza' note, but that would be better added to the "Comments" tag, as much more space available, plus the playlist can also be configured to check the Comments tag.
Create Auto-playlists with config settings of...
Grouping
contains Driving (Will list All tracks that have the word "Driving" plus any other in the Grouping tag).
OR
Grouping
is Driving (Will list All tracks that have ONLY the word "Driving" and no other in the Grouping tag).
I also use this method for RATING my tracks, (Grouping [4 Star 5 Star], then the star ratings always stays with the music file, which can be most useful if ever you have to do a complete re-install..
Example Auto-playlist:-
Music track source: Library (music library)
Display using view: default
Match: All of the following rules
Grouping contains WINTER
Grouping contains DRIVING
Shuffle: Random
Select by: Track
Automatically refresh the matching tracks
