Author Topic: 2 way sync w/android or DAP?  (Read 3629 times)
kro4k
In reading over the website and forum it seems that there is no way to sync ratings on an android back to MB. I understand this is because there is no "MB player" for android (is there a preferred/recommended paid/unpaid android music players with MB?). As of 2018 this seemed to be the case.
Is that still true?
And for those using other DAPs like Fiio, is 2 way sync possible in that situation?
Thanks!
bierdc
Pull up your device in MB and check the settings tab for 2-way synchronization. I may be mistaken, but I seem to remember that feature being able to perform the task you desire (and I'm also pretty sure that it was supported by my Moto Z with the SD card mounted as an external storage device).
Alternatively, you could look into indirect/2-stage syncing over wifi:
https://musicbee.fandom.com/wiki/Synchronize_Android_by_Wifi
Theoretically, you could permit both clients to modify the files and apply the most recent changes to all devices.
As for Android apps, all I can say is that I settled on Pulsar but it won't work for you because it uses the "love it" or "neutral" rating seemingly independent of the files' metadata. I'm ok with that because I only sync 4+ star files and very rarely change them.
I too would love to hear if there is a recommended app since there is [very sadly] no MB for mobile.
And I don't know what is the Fiio DAP of which you speak, but I've seen that some dedicated DAPs run a version of Android--and if it does, perhaps either of the methods above would apply to that too.
No, it doesn't work like that. Currently the WiFi sync is one-way only - from MB to Android. It is still an alpha build and there are things that haven't been implemented yet. At this point Steven is trying to make sure basic one-way syncing works.
bierdc
Maybe my understanding of the process is off then  :-\
If MB is writing your ratings to the files themselves, then any 3rd-party syncing software should be able to match the files' metadata on each device, should it not?
EDIT: Nevermind, I think I see the problem.
Last Edit: March 10, 2019, 04:44:56 AM by bierdc
