I know there's supposed to be 2-way sync with playlists in GMMP, but I'm not sure how this works. Will it only sync changes to a playlist that first came from MusicBee? Will it sync playlists that were created with GMMP?
I have my MusicBee files, including audio files and playlists, on the SD card, but MusicBee has the internal GMMP playlists folder by default, and if I try to change it and then do a sync preview, I get an "unrecoverable error" message. If I go straight to doing a sync, the sync works but the folder is not actually changed.
