Hi Steven!
I LOVE MB! Really and the WiFI Sync option is a killer feature! Thanks 4 your work. You are doing a great job!
I am using 3.3.7003 and syncronication is a little bit buggy at the moment. Sometimes it works, sometimes not.
Actually it stops with the android message: A non-recoverable error occured during the synchronization process.... and the log files say (german phone!):
"März 08, 2019 9:48:15 VORM. com.getmusicbee.musicbeewifisync.ErrorHandler logError
SCHWERWIEGEND: looper [CLT-L29, 9, 0.2.6] command=ReceiveFile: java.io.UTFDataFormatException: malformed input around byte 114"
"März 08, 2019 9:52:25 VORM. com.getmusicbee.musicbeewifisync.ErrorHandler logError
SCHWERWIEGEND: looper [CLT-L29, 9, 0.2.6] command=ShowPreviewResults: java.io.UTFDataFormatException: malformed input around byte 108"
CLT-L29 is the name on my phone (Android 9) using only the internal device.
Maybe this info can help you with the development.
Once again: THANK YOU!
chris
