Author Topic: Wifi android device synching  (Read 240902 times)
Apparently it doesn't match my previous configuration:
https://i.imgur.com/bZ30KBH.jpg
check the error log on the musicbee side (help/ support/ view error log)
To the others, are you running MB with the "wifi synching" checkbox ticked in the MusicBee device preferences tab?
I would need to see the log on your phone and also the last entries in the musicbee error log
Last Edit: February 15, 2019, 08:33:01 AM by Steven
Using 3.3.6982 I have "enable Wifi transfer with android phones" ticked. I have installed the Wifi sync app on my Samsung S8 running Android v8.0. Clicking "sync now" results in the "can't match device..." error. There is nothing in the MB error log. And I can't find the log on my phone as I'm not sure where it is located. If you could tell me the name of the log on the Android I could search for it.
On my FiiO X5, which is running Android 5.1 Lollipop (with no ability to update it) I can see the app in the play store, but when I try to install it, it's says "no eligible devices." I need to dig into this part a little more so for right now I'm only concerned with the Samsung not being able to connect. I'll update the X5 situation when I actually get the app installed.
Check out the MusicBee Wiki.
mb 3.3.6982, wi-fi sync enabled, one plus 2 (android 6.0). I get "server not found" error on my phone. no log on the phone, no related entries in the log on pc.
Now that I've finally gotten the app installed on the X5, I selected 'removable SD card' and pressed 'locate server.' This results in 'Server not found. Ensure MB is running on your computer and dWindows firewall is not blocking MB.'
I have temporarily disabled all my security software and confirmed that MB is running and the box is ticked to enable wifi transfer.
in the Download folder as: MusicBeeWifiSyncErrorLog.txt
you need to access the file via the Android Files app
This is from the Samsung running Android 8.0
Feb 15, 2019 8:07:32 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogInfo
INFO: Start: MB unable to match volume names (1)
INFO: Start: Phone memory
Freddy Barker
  • 🎧 MB 3.4.7628P
[EDIT]
Galaxy A5 (SM-A500FU) and Galaxy J5 (SM-J500FN) - Android 6.0.1 (Marshmallow)
Device storage/Download/ MusicBeeWifiSyncErrorLog.txt.lck
15 Feb 2019 13:19:00 com.getmusicbee.musicbeewifisync.ErrorHandler LogError
Sn to /192.168.1.254 (port 27304) after 2500ms: isConnected failed: ECONNREFUSED (Connection refused)
15 Feb 2019 13:19:00 com.getmusicbee.musicbeewifisync.ErrorHandler LogInfo
INFO: Ping: 192.168.1.71
SEVERE: Ping: failed to connect to /192.168.1.71 (port 27304) after 2500ms: isConnected failed: ECONNREFUSED (Connection refused)
INFO: Ping: 192.168.1.67
15 Feb 2019 13:19:01 com.getmusicbee.musicbeewifisync.ErrorHandler LogError
SEVERE: Ping: failed to connect to /192.168.1.67 (port 27304) after 2500ms: isConnected failed: ECONNREFUSED (Connection refused)
Last Edit: February 15, 2019, 07:18:06 PM by Freddy Barker
can you PM me a link to your settings file (help/ support/ view settings)
PM sent
Here's the error log from the FiiO X5. It looks like it's trying to connect to every device on my network. And being refused by all of them. It should only be trying to connect to 192.168.1.101, which isn't showing in the error log. Note that the log seems to contain more than one attempt to connect.
Feb 15, 2019 8:52:43 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogInfo
INFO: FindCandidate: Probing 192.168.1.
Feb 15, 2019 8:52:46 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogInfo
INFO: FindCandidate: 192.168.1.1
INFO: FindCandidate: 192.168.1.2
INFO: FindCandidate: 192.168.1.10
INFO: FindCandidate: 192.168.1.11
INFO: FindCandidate: 192.168.1.103
INFO: FindCandidate: 192.168.1.202
INFO: FindCandidate: 192.168.1.201
INFO: FindCandidate: 192.168.1.115
Feb 15, 2019 8:53:16 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogInfo
INFO: Ping: 192.168.1.1
Feb 15, 2019 8:53:16 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogError
SEVERE: Ping: failed to connect to /192.168.1.1 (port 27304) after 2500ms: isConnected failed: ECONNREFUSED (Connection refused)
INFO: Ping: 192.168.1.2
SEVERE: Ping: failed to connect to /192.168.1.2 (port 27304) after 2500ms: isConnected failed: ECONNREFUSED (Connection refused)
INFO: Ping: 192.168.1.10
SEVERE: Ping: failed to connect to /192.168.1.10 (port 27304) after 2500ms: isConnected failed: ECONNREFUSED (Connection refused)
INFO: Ping: 192.168.1.11
SEVERE: Ping: failed to connect to /192.168.1.11 (port 27304) after 2500ms: isConnected failed: ECONNREFUSED (Connection refused)
INFO: Ping: 192.168.1.103
SEVERE: Ping: failed to connect to /192.168.1.103 (port 27304) after 2500ms: isConnected failed: ECONNREFUSED (Connection refused)
INFO: Ping: 192.168.1.202
SEVERE: Ping: failed to connect to /192.168.1.202 (port 27304) after 2500ms: isConnected failed: ECONNREFUSED (Connection refused)
INFO: Ping: 192.168.1.201
SEVERE: Ping: failed to connect to /192.168.1.201 (port 27304) after 2500ms: isConnected failed: ECONNREFUSED (Connection refused)
INFO: Ping: 192.168.1.115
Feb 15, 2019 8:53:17 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogError
SEVERE: Ping: failed to connect to /192.168.1.115 (port 27304) after 2500ms: isConnected failed: ECONNREFUSED (Connection refused)
Feb 15, 2019 8:55:19 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogInfo
Feb 15, 2019 8:55:19 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogError
Feb 15, 2019 8:55:20 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogError
Feb 15, 2019 8:55:20 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogInfo
Feb 15, 2019 8:55:21 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogError
Feb 15, 2019 8:56:09 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogInfo
Feb 15, 2019 8:56:09 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogError
Feb 15, 2019 8:56:11 AM com.getmusicbee.musicbeewifisync.ErrorHandler LogError
klint
Hi Steven
The app cannot locate the server but the log file is empty. The Windows firewall seems to be ok ("private" is on and I'm on a private network). The wifi setting is checked app is MB. Is there anything else I should check?
Thanks
Other firewalls on the network, potentially?
Use TCPView to see which port MusicBee is listening on.
It's listening to port 27304.
But I just have scanned the ports of the PC from my phone and none is open. So, there must be another firewall. Too bad for me :) (I can't do a thing as it's my office laptop).
Last Edit: February 15, 2019, 05:39:19 PM by klint
PM sent
thanks. Can you confirm its the "SM-G950U\Phone" device?
If so, the path explains why its not working and i will need to make a change on the android side as something that is working for me doesnt appear to work for anyone else
zkhcohen
2/14/2019 2:51:35 PM - Unable to match: SM-G955U\Card\ to a volume: Phone memory; SD card;
2/14/2019 2:51:56 PM - Unable to match: SM-G955U\Card\ to a volume: Phone memory; SD card;
2/14/2019 2:52:29 PM - Unable to match: SM-G955U\Card\ to a volume: Phone memory; SD card;
This is the storage path I have configured for the Device Settings in MusicBee:
SM-G955U\Card\
Yes, that's my Samsung S8.
