You're welcome.
You don't say what version you're currently running, nor how it's installed. The simple thing to do is to download the 3.4 patch from my sig and apply it. You can write directly over 3.3. And if you're using the portable version, just copy the entire MB directory to somewhere safe (like a flash drive) and apply the patch. If you don't like it, copy back what you saved to the flash drive.
