Author Topic: Display actual bitrate for stream vs. Icecast header value  (Read 878 times)
When playing FLAC radio streams, MusicBee takes the bitrate value displayed in the Track Information properties from whatever is being sent in the Icecast "icy-br" header.  That value is usually not accurate, and ends up displaying obviously wrong rates like 128kbs for FLAC streams that are actually 900+.  Can a change be made that allows the actual stream bitrate to be shown instead?  Comparing players in wishlist requests is normally not a valid argument, but just to show that it's not a restriction of the BASS library, both XMPlay and AIMP do this.  Thanks for your consideration from a stream fan.
the next v3.3 update uses the bass functionality for bitrate
Last Edit: March 17, 2019, 08:01:19 PM by Steven
Ah, this works BEAUTIFULLY!  In addition to real FLAC bitrates, it's also showing improved bitrate displays for Opus and AAC+ streams.  Thanks, Steven!
