I was using the Copy Tag function to copy data from one frame and append it to the end of another. Somewhere half way though the operation, I noticed that the computer screen did not have MusicBee on it anymore. The app crashed and closed. In the log I see:
2/26/2019 7:55:40 PM - 10.0.17134.0 - 3.2.6902.32258 - System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
at System.String.InternalSubString(Int32 startIndex, Int32 length)
at System.String.Substring(Int32 startIndex, Int32 length)
at #=zpIyIGMKAjgJgqIRF6g==.#=z_plnHVe5ixDO()
at #=zehcg8y8_ziYqQJa27keIrUU=.#=zk_VLYlUeovqx(TagCode #=zsZZSPK8=)
at #=zqp1eepsFPEZNa19vPHhOcpI=.#=zYIOjEGROwjRE(#=zehcg8y8_ziYqQJa27keIrUU= #=zTZplbeI=)
at #=z0tKmjN7s8$nDGDk7Mq2EKqc=.#=zAwMEgbo=(#=zehcg8y8_ziYqQJa27keIrUU= #=zTZplbeI=)
at #=zHjCgA5XlLCr5T3K2cgID$Q4=.#=zRd5De0pkcfiv.#=zKudFNjoxLfmy(#=zabPgEBjVnLcbMC7FrAcqADKQ5Eef #=z5Zj2D38=, #=z0tKmjN7s8$nDGDk7Mq2EKqc= #=zRJUPeDI=, Boolean #=z87TMBs9sOgJO)
at #=zjyXLHZtxcuOO$I_VXEWeIlk=.#=zuCplUYrO8Xi3dFBnRA==(#=zs2BceXvhc5ayfbP7iCv2QXneZdid #=z07RZ9TZ5ID7p, Boolean #=z87TMBs9sOgJO)
at #=zs2BceXvhc5ayfbP7iCv2QXneZdid.#=zt5rMgL2lwdUL(Boolean #=zw2JG0DEDWI55, SortOrder #=zbvcW3VE9YWHcMFX7Ug==)
at #=zs2BceXvhc5ayfbP7iCv2QXneZdid.#=zHAALHbo=(SortOrder #=zbvcW3VE9YWHcMFX7Ug==)
at #=zGQ2Dv0Sa2dr8x55F8dLAfPzu1vYq.#=qmktigoxYMwmyKBq5nV0JmtNYcGWUCRPVHzJpygPo8nw=._Lambda$__0()
2/26/2019 7:55:40 PM - 10.0.17134.0 - 3.2.6902.32258P - System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
2/26/2019 7:55:48 PM - 10.0.17134.0 - 3.2.6902.32258 - System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
at #=zf67MEopCrwJkUkPlGumBqLA=.#=zworXhnS61bwz.#=zFHD6TAw=.#=zhZKKrPPRDflt(#=zpIyIGMKAjgJgqIRF6g== #=zRFcHc7Q=)
at #=zrRFBP2GGFDmqtu3KROVPp9ewHUM0.#=zMIsL2mU=(#=zpIyIGMKAjgJgqIRF6g== #=zRFcHc7Q=)
at #=z986Ri2pydeujdzRNddX3Q3kGN9y9.#=qiNzXrPS6Uod4L88iP6FRc2ZhkHHAVHYL1nlCEz3dWV0=._Lambda$__0()
at #=z986Ri2pydeujdzRNddX3Q3kGN9y9.#=zxKmunU6OPlaAjpD$r17UJFU5tIYm(#=zehcg8y8_ziYqQJa27keIrUU= #=zTZplbeI=, #=zBizY49UikWWEDZdYG9lujmA= #=zoxmzLLo=, Boolean #=z4nKBo04=)
at #=z986Ri2pydeujdzRNddX3Q3kGN9y9.#=z4Jn5tj_d3ZjITVT6PA==(#=zehcg8y8_ziYqQJa27keIrUU= #=zTZplbeI=, List`1 #=zSnLWsdK9zuF6ZpTHjg==)
at #=z986Ri2pydeujdzRNddX3Q3kGN9y9.#=zaygo350=(#=zehcg8y8_ziYqQJa27keIrUU= #=zTZplbeI=, List`1 #=zSnLWsdK9zuF6ZpTHjg==)
at #=zHjCgA5XlLCr5T3K2cgID$Q4=.#=zIMpQgqgHCfqy.#=zaygo350=(#=zgrlhBIU218nbMLgxcwSBuBs_qOGf #=zmPTlH6A=, Boolean #=z34$Zh$l$Nz6Q, List`1 #=zDJoiv0U=, List`1 #=z5jJ0sdTwHPczPINQi8gv0dTGQISbfM8pHQ==)
2/26/2019 7:55:48 PM - 10.0.17134.0 - 3.2.6902.32258P - System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
2/26/2019 7:55:52 PM - 10.0.17134.0 - 3.2.6902.32258 - System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
at System.Collections.Generic.SortedDictionary`2..ctor(IComparer`1 comparer)
at MusicBeePlugin.BackupType.save(String fileName)
at MusicBeePlugin.BackupIndex.saveBackup(String backupName, String statusbarText, Boolean isAutocreatedParam)
at MusicBeePlugin.Plugin.regularAutobackup(Object state)
at System.Threading.TimerQueueTimer.CallCallbackInContext(Object state)
at System.Threading.TimerQueueTimer.CallCallback()
at System.Threading.TimerQueueTimer.Fire()
at System.Threading.TimerQueue.FireNextTimers()
at System.Threading.TimerQueue.AppDomainTimerCallback()
2/26/2019 7:55:52 PM - 10.0.17134.0 - 3.2.6902.32258P - System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
2/26/2019 7:55:54 PM - 10.0.17134.0 - 3.2.6902.32258 - System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
at System.Collections.Generic.List`1.set_Capacity(Int32 value)
at System.Collections.Generic.List`1.EnsureCapacity(Int32 min)
at System.Collections.Generic.List`1.Add(T item)
at #=zGQ2Dv0Sa2dr8x55F8dLAfPzu1vYq.#=zW2d3AXyaxtn3.#=qoSrv$vXRrN81135a7K1ifeQyJQluTQeEiIAORdtvyxc=._Lambda$__1()
at #=zGQ2Dv0Sa2dr8x55F8dLAfPzu1vYq.#=zW2d3AXyaxtn3.#=zXVhvfOjHJ14X(List`1 #=zgJymtQ8=, Int32 #=zsDdCV7Q=, String #=z5w_QPMI3ZI1bkaP9kA==, Boolean #=z7wDR9QF$gKgUi1b7Hw==, #=zqp1eepsFPEZNa19vPHhOcpI=[] #=z95oYZOrGuGakL9qJnQ==)
at #=zGQ2Dv0Sa2dr8x55F8dLAfPzu1vYq.#=zW2d3AXyaxtn3.#=zOhMOnrE=(List`1 #=zgJymtQ8=)
at #=zGQ2Dv0Sa2dr8x55F8dLAfPzu1vYq.#=zW2d3AXyaxtn3.#=q5JD4qNPcXgfMs82WZjK$jnW5L0i9GhHkJuOP58IpWcA=._Lambda$__0()
2/26/2019 7:55:54 PM - 10.0.17134.0 - 3.2.6902.32258P - System.OutOfMemoryException: Exception of type 'System.OutOfMemoryException' was thrown.
Nothing further in the Windows event log. Now I have a big mess as my files are unsynchronized. Can this tool handle a large number of files with stability?
I can confirm that my system is not out of memory. Windows was using 6GB in total and I had 11GB of memory free at the time of the crash.
Microsoft Windows [Version 10.0.17134.590], MusicBee 3.2.6902
