Author Topic: Folders sorted disregarding the "the"  (Read 1131 times)
ugoveri
I would like to have the folders sorted disregarding the "the" in some bands/group names (eg: The Doors, The Cure). This way the, "The Cure would be grouped under the letter "C" and not the letter "T".
This is not at all critical. I am very much happy with this music player as it is already.
Edit > Preferences > Sorting/Grouping > ignore words xxx when sorting by Artist, Album or Title.
Make sure to tick the box to the left to enable it. In the 'ignore words' field enter The  and anything else you want ignored separated by a comma. For example
The, ', A, (, $, #, ", “
You can also right-click on a track or album and go to the Sorting tab. You can then define how you want to sort the track, album, album artist, or artist. Be sure to tick 'enable custom sorting...' at the top of the config window.
Hi, welcome to the forum!
If you're referring to the folders created by file organization, you'll need to adjust your template to use sort artist or sort album artist. phred's advice will help you control exactly what MusicBee uses for sort values.
ugoveri
Thanks to both. After all it was already there. Fantastic. Very good piece of software.
