Author Topic: Can't find Views  (Read 1669 times)
serenepdx
I have a list of artists on the left panel. It used to be that if I clicked on an artist on the left panel, then the main panel would show the albums and tracks in one list.  Now I have pictures of each album, and I can click to see the tracks. I would love to switch back and forth, but I can't for the life of me figure out what happened.
The wiki states: "At the top left of the main panel you will find a menu with view options. These are the four default views available:
Tracks, Album and Tracks, Album Covers, Artists." My main panel has "Artist Information" in the top left corner, but it doesn't show theres views in the drop down.  In the musicbee dropdown menu at the very top of the screen there is a choice for View, but it doesn't show these options either. I must be missing something obvious.
https://drive.google.com/file/d/1axGJCcjBoznkzRhk7M-5g1G-nTHMB1fo/view?usp=sharing
You likely have "Hide Header Menu" activated.  Right click the area above the main panel and deselect that, then you'll see the view options.
You can also click the Configure Layout icon next to the search box at the upper right, then "Main Panel" and select a view from there.
serenepdx
I'm not as crazy as I thought. Hide Header Menus is not activated, and I don't see those views when I get to configure layout, main panel either. Here's the screenshot
https://drive.google.com/open?id=1lyY8aaACHYvzjIwSdGLZawhvsxWZiROv
and here are the two from the prior post. The insert image feature isn't working well (or I don't know how to use it):
https://drive.google.com/open?id=1XDRMvAMdfV6xwnpLfnHvKZNFdQi_Msro
https://drive.google.com/open?id=1axGJCcjBoznkzRhk7M-5g1G-nTHMB1fo
Last Edit: February 20, 2019, 06:08:59 PM by serenepdx
Your images aren't public, and I'm not signing into Google to view them.
serenepdx
You're right. I got a "shareable link" so "anyone" can view them, but it doesn't work unless you're logged in to Google.
Whether I show or hide header panel, I still can't find a menu that let's me set the view. Same thing when I click on the panels icon next to the magnifying glass.
Those are the two places I know of to find it:
serenepdx
Interestingly, I simply don't have the menu options for tracks, album and tracks, album covers, etc. as options. Maybe I'll have to just uninstall an reinstall.
