Author Topic: configurable copy string  (Read 6020 times)
bearmann
Hi Steve,
would it be possible to make a customizable copy string?
At this moment its just <title>/n<artist>/n<album>/n<year> but that's not very pleasant in some cases (chat, for instance).
It'd be great if there were a string formatting field somewhere... :)
Thanks a lot.
bearmann
yes that is fair enough - at the moment it uses the configuration from the 'details' tab in the now playing list (see the button above that tab on the right to change the configuration), so if you dont care about 'details' tab in the now playing list, just change it there. You can also include multiple fields on the same line and text in between as well.
i'll add a separate configuration for the clipboard copy function
i added a configuration in the Preferences/ Tags panel in tonights update
by default its just Artist - Title
