Author Topic: Clipping indicator in the Wave display?  (Read 1420 times)
captain_paranoia
Just pondering the Loudness Wars, and the ability of tools like Audacity to show FSD clipping in files. Since MB has a wave display, is there an option to add clipping indication (e.g a red sample line) in the wave display?
And, if not, would there be any support for a feature request to do this?
Or even to add a DR measurement tool/tagger in MB? There's a previous discussion about using external tools to add DR tags:
https://getmusicbee.com/forum/index.php?topic=24599.msg141794#msg141794
Audiophil3
i detect musicbee is crashing if mp3 files with clipping exist, and direct sound is configured.
with wasapi output the file is just skipped with musicbee.
CritterMan
  • Now with FiiO M11!
MB does not have this feature at present. Requests for new features can be posted in the Musicbee Wishlist forum. I use the Send To function to open tracks in Audacity if I need to check for clipping.
There has been discussion, and a plugin is in development. See the thread for that plugin here: https://getmusicbee.com/forum/index.php?topic=28208.msg156768#msg156768
Please create a list of steps to reproduce this issue and start a new thread in the Bug Reports forum. You will likely be asked to provide a file that you can reproduce the issue with.
Something's wrong somewhere with your system.  Just playing a file that has clipping will not cause MusicBee to crash or skip a file.  Providing some details as to your MusicBee version, player prefs setup, active plugins, and OS may help someone suggest a reason, as well as uploading one of the files that causes this behavior.
