So, a bit of background:
For ease in sorting and knowing what to back up vs. what I still have CDs I could re-rip in the event of data loss, my library is spread across a few directories:
-FLAC Music
-FLAC Purchased
-MP3 Music
You get the idea. Within these, the tree structure is Artist\Year - Album\Artist - ## - Track.flac or whatever the extension happens to be.
I use a pair of playlists to sync files to a pair of MicroSD cards that are used in a Fiio portable player. The sync is set to maintain the file and folder naming conventions.
Up until relatively recently (past month or two), files in library folders ignored those initial "format" folders and everything starting with the artist folder was synced to the microSD cards I use in my Fiio player. all artist folders were commingled regardless of which library folder they were located in.
More recently, the sync has included those format folders, which is a pain as I use the file navigator on my Fiio as my primary mode of navigation AND some artists have albums in multiple formats, so where I previously had everything by a given artist lumped together, now things are spread out.
In the past, this behavior would only occur if something NOT present in a library folder was picked up in a scan and added to the sync playlists I use to keep things simple.
I've checked my settings and found nothing obvious to cause the change, so I'm left to assume it occurred with an update. I have tried using the naming template to address this, but the year convention in my folders incorporates months where multiple releases in a given year took place and the template seems to cut off the year at 4 digits, so it defeats that organizational strategy. Is there something I can change in terms of settings to fix the sync with file structure maintained OR to use the template without having the problem with chronological sort?
Thanks in advance for any input here. Love the program and, all told, this is a minor inconvenience, but I'd still like to fix it - if possible.
