Hi trying to use the Windows Store version of MusicBee and it keeps giving me this error.
12/02/2019 15:14:36 - 10.0.17134.0 - 3.2.6827.32939 - System.IO.FileNotFoundException: The system cannot find the file specified. [C:\Program Files (x86)\MusicBee\Configuration.xml]
at #=z4$ucNWNbXnMtRdEYGQBqltI=.#=zrGplkqML6ihm.#=zCMpeRYQ=.#=zNilJn1mMo3HK(#=z0_ypH2cyEw0FHUGBuw== #=zbw$scCI=, FileShare #=zQ84njxs=, FileOptions #=ziFl7n$0=, Boolean #=z8B5LbEIlNN$p)
at #=zl3G$ts$_9zIRoQdlmns30$2c9Koz.#=zcWUfq7wMikVm()
at #=zl3G$ts$_9zIRoQdlmns30$2c9Koz.Main(String[] args)
12/02/2019 15:34:39 - 10.0.17134.0 - 3.2.6902.17698 - System.TypeInitializationException: The type initializer for '#=zuASor2HRNR9oQGG8zGSN9yY=' threw an exception. ---> System.NullReferenceException: Object reference not set to an instance of an object.
at #=zuASor2HRNR9oQGG8zGSN9yY=..cctor()
at #=zuASor2HRNR9oQGG8zGSN9yY=..ctor(Boolean #=zd4_srziaj8Cu1xXB8w==, Boolean #=zz9TW32yCRYNJ)
at #=zniBT16xsnZT2cLGjDXGWVGEqyJ$e..ctor()
at #=zfujPmLP5n_FlK$gprBR_lxWc7wmE.Main(String[] args)
12/02/2019 15:34:39 - 10.0.17134.0 - 3.2.6902.17698Store - System.TypeInitializationException: The type initializer for '#=zuASor2HRNR9oQGG8zGSN9yY=' threw an exception. ---> System.NullReferenceException: Object reference not set to an instance of an object.
The major problem being is that the Windows Store version of MusicBee isn't installed in - C:\Program Files (x86)\MusicBee\
It's located here - C:\Program Files\WindowsApps\50072StevenMayall.MusicBee_3.2.4.0_x86__kcr266et74avj\win32
So it's trying to look for the .xml in the completely incorrect location, I haven't yet been able to find how to tell where MusicBee should search for it's files.
Any help with this would be greatly appreciated, thank you.
