Author Topic: Joint Stereo or Stereo  (Read 2454 times)
BriAsylum13
Which is better? Joint Stereo or Stereo How can I make the file converter switch from JS to S or vice versa?
Read the additional information section. There's a reason joint stereo is the default:
https://wiki.hydrogenaud.io/index.php?title=Joint_stereo
This tells you everything about command line switches and what they do:
https://wiki.hydrogenaud.io/index.php?title=Lame
But, seriously, just use a VBR preset that gives you the quality and file size you want. The people who set them up know more about this stuff than most of us ever will. Messing around with custom command lines is highly likely (almost guaranteed unless you're an expert) to give you much worse results.
Also, this section is for MusicBee specific questions.
Last Edit: February 11, 2019, 01:24:13 AM by frankz
