Author Topic: cannot uninstall plugin - specifically "lyrics reloaded"  (Read 1961 times)
green_scarf
I am trying to install the lyrics reloaded plugin because I have been having troubles with it. So I decided to uninstall it and reinstall to see i that would make any difference - except I was met with a message saying it was not possible to uninstall:
MusicBee v3.2.6902.32258 (Win10.0), 10 Feb 2019 23:43:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.NullReferenceException: Object reference not set to an instance of an object.
   at MusicBeePlugin.Plugin.Uninstall()
   at #=zI1NgCaqlkaM5BICoqA==.#=zb4DUNQE=()
would anyone be able to help me fix this problem?
Try these suggestions:
https://getmusicbee.com/forum/index.php?topic=25406.msg152998#msg152998
https://getmusicbee.com/forum/index.php?topic=25406.msg153002#msg153002
That error doesn't seem to be generated from the plug-in like the other error, though, unless I'm misreading it.  Did you delete the plugin files without uninstalling it?
Last Edit: February 10, 2019, 02:29:00 PM by frankz
