My portable device, an AK SP1000 (Android with MTP), has 2 storage locations (Internal, SD)
The Sync works well but I have to create Playlists that will be synced depending on the location and manually change the path of the storage location.
Would it be possible to split the GUI in two identical processes to initiate 1 at all sync for portable devices with 2 storage locations and different playlists on different locations ?
or "send to..." SD1 or SD2
I tried this workaround by using the "virtual device #1 and #2" but I am unable to select a folder and the end and click OK
Regards
