point of view:
all files are cataloged, tagged and complete, therefore all delete functions
in MB are only a risc of dataloss.
Since using Musicbee i have never used
1.) remove from Libery because MB reside over monitored folders
2.) remove from disk because i move unwanted files to special folders.
I think the deletion of files in MB is to easy.
(crtl+a del enter) in a Playlist Tab is useful - but when i am on a Library Tab ?
Who reads confirmations carefully in less than a second - ok, nothing happed - but it is possible.
My request is to have the possibility to disable del from library, del from disc and shift/del
i hope this could be a additional point in the hotkey section.
-Remove-Delete-Erease-
(File: Erease --- [None][Shift+Del])
