Author Topic: How to turn off confirmation while deleting songs?  (Read 692 times)
bfallona
I have a ton of albums that sorted by artist ie greatest hits of 60's but now have 100's of each artist with 2 songs each. It's taking forever to delete each on and confirm twice.  I went into preference but couldn't click it off.
Try un-checking "confirm permanent file deletion(using SHIFT delete)" in Prefs/General/Conformations.  Then, delete the files using SHIFT+Delete from your keyboard instead of just hitting the Del key or using the context menu.
bfallona
Thanks that works fine.  It would be nice to be able to either look in the artist colum and then right click or just highlight & hit delete key.  Should I post that in the wish list forum?
click in the artist colum, then press ctrl+a, then shift+del?
