Hey MB forum,
i'm finally attempting to completely get my extremely messy DJ library sorted once and for all.
Since i have thousands of thousands of copies of the same file, referenced in dozens of playlist files, i want to use the 'Move Files to Organized Folder' method for songs in my library since MusicBee will keep the libraries' playlists fixed when moving files with this method.
However since i have a lot of duplicates of the exact same songs MB won't let me move a majority of those files because they already exist at their destination (an almost-default
<Album Artist>\<Album>\<Track#> <Artist> - <Title>
scheme).
Since i've already moved all versions of songs once already (i.e. all files that i actually need for the playlists are already sorted) i simply need to get all the references in the playlists adjusted for that.
The easiest way would be to simply force moving all the songs into the Organized Folder, overwriting existing files (since i know all of them are the same files) because it would also update the playlists.
Any ideas on how i can achieve this?
Regards,
sinusstudios aka. waffeln
