I want:
/storage/3EC3-1FFB/Music/blah
I get:
..\Music\Shoji Meguro\Persona 5 Sounds of Rebellion\1-18 - Last Surprise.mp3
MB v3.3.6952
Windows 10
I'm syncing to a virtual folder on my PC.
Here are my relevant settings:
https://imgur.com/gallery/zSdooarSo as you can see, it ignores the rename piece in the global settings. Device settings ignores the unix bit, but not the relative part. Export doesn't work properly either - it puts my PC's music file location in instead of the relative path as it says it should be on the global library settings.
Not sure where to go from here. Thanks for looking.
