Author Topic: Convert on Import  (Read 508 times)
Hentoad
Is there a way to get MusicBee to convert files when they get imported, kinda like calculating replaygain on import? And if so, to only convert FLACs.
I want to use the file converter to compress FLACs on import to save a few MBs.
no, but you can import files to inbox first, then convert, retag them, etc. and only after that manually move them all at once to library.
