Author Topic: << Rewind & Forward >> Some Seconds (sp. in Podcasts)  (Read 8563 times)
washere
I just found out about MusicBee yesterday. I imported my 140 subscriptions (needed a tiny edit in xml) to MusicBee. I love it. Thanks to the dev.
Most Podcast players, and audio book players, have buttons to go back & forth a number of seconds. Such as 10 seconds or 20 or 30. Usually the user can set this time parameter, in most apps.
_______________________________________________________________________
1) Can we have these 2? So the bottom panel will look like:
Optional:
2) Can we customize the number of seconds (same parameter for both)?
3) Can we assign keyboard shortcuts too like many apps let us?
If not assigning the left arrow key ( < ) and right arrow key ( > ) would be great as they are standard.
Would be nice to assign space-bar key to play/pause too.
Musicbee has become my favorite podcast player already. Podcasts are a booming industry recently. Many good media content providers are also now generating content. I think more podcast standard features will boost the awareness for MusicBee too as PR device.
Thanks again.
Last Edit: January 10, 2019, 05:37:53 PM by washere
Edit->Edit Preferences->Hotkeys has settings available for Skip Back / Forward 1 minute and Skip Back or Forward 5 Minutes if that helps get you closer to what you want while your wishlist is out here.
washere
Thanks frankz,
I set the two hotkeys but they are not functioning. I also tried enabling them as global (applies in all Windows, not working elsewhere) but still not working. I tried moving the focus to bottom panel and seekbar too. Also several relaunches. It has 5secs options too.
The seekbar animation flickers when I use the assigned hotkey (< left arrow key & right >) so it is registering.
If they could be made to work
15 seconds and 30 seconds could be added as options, would be great.
Thanks again.
washere
UPDATE:
* So I rebooted the laptop (Win 10 Pro, latest updates, brand new Dell XPS 13 i7-16gb ultrabook) and assigned 2 keys, instead of arrow keys, C & V. Skip started working. I assumed arrow keys might not be assignable.
* I assigned & tried the arrow keys, they worked too now. So problem seems to be fixed by rebooting.
* I had problems with resume position & play on relaunch set in preferences, didn't work before. So I went to the middle of a podcast and relaunched. Resume playback & position prefs both work now too.
Lesson, if people are having problems after changing settings, not taking effect, reboot windows!
DESIRABLE:
+ Would be good to have the 2 skip buttons per OP request << & >>
+ Good to have 2 new Hotkey options for Skip (back & Forth): 15 seconds + 30 Seconds
Because  the current two options: 5-seconds is too short and 1-minute is too long, for Podcasts & Audio books.
I assigned the spacebar to MediaPlayPause too. It was a global setting but the Dell XPS 13 play/pause button (Fn + F5) still seems to work on other media players.
Thanks again to frankz & the dev.
Last Edit: January 11, 2019, 12:19:08 AM by washere
KangNi
+1
It's not exactly what I was suggested hereinafter, but it goes in the same direction:
Many (compact) CD audio players offer combined keys for seek (search) forward/backward and skip to next/previous track.
- pressing them short will jump to next/previous track instantly
- pressing longer than ~1 sec will start to speed-up the the playback and increasing the speed as longer the button keep holding down
- release the skip/seek(search) button will continue normal playback
In case of nobody can understand what I mean - just remember your old Discman and have look here ...
https://youtu.be/6ugpH2_5Vfo
It would be awesome if this functionality could be provided at least in the MB hotkey list and optional for the skip buttons on the MB GUI too.
It would allow to seek (search/scan) and skipping tracks with the SAME skip-track mediakeys/hotkeys just by vary the hold down time.
Control SEEKING/SEARCHING via dedicated media keys on some keybords also would working perfectly therefore.
My understanding - and I would say it's common standard - of the seek/skip symbols is as follows:
  ◄◄ / ►►   dedicated seek backward / forward (MB uses this symbols for skipping - contrary to the "common standard")
   ▐◄ / ►▌    dedicated skip backward / forward
▐◄◄ / ►►▌ combined seek & skip backward / forward
So, once seeking is implemented in MB (optional via GUI controls) the GUI buttons  ◄◄  /  ►► than should change to this ▐◄◄  /  ►►▌ IMHO, but from my view most importantly would it be providing hotkeys for that functionality.
Thanks for considering.
The original thread can be found here:
https://getmusicbee.com/forum/index.php?topic=20470.msg121377#msg121377
Greetings
Last Edit: September 04, 2020, 08:36:55 AM by KangNi
washere
BUTTONS TO SKIP Back/Forth WITHIN TRACK:
Some further thoughts. The player controls, there are some structural issues WRT current UI/UX standards.
On our physical mp3 players and most software media players:
* When we press the skip back or forth ( ¦<<  or  >>¦ )
  - Media skips back/forth to the beginning/end of current track
With current MusicBee, the skip back skips to previous podcast, not beginning of current track as is norm.  Understandable, if not ideal, since there is no skip within track options. My suggestion in this thread would fix that.
Some media or mp3 players are even better than the norm. There 4 additional controls. Some offer all 4.
1* Skip back: skip within track (either some chunk of time or to beginning of current track)
2* If within a section at the start of a track (say within the first 30 seconds) and pressed (again or just only press), they then skip to previous track
3* Some let the user skip in real time while keeping the button pressed and stop skipping when button is released
4* Some increrase the rate of skipping (momentum), the longer the skip back/forth button is pressed
I am not asking for all 4 features. In fact I am asking for none. I am asking for a feature in this thread that would at least give some skip option within current track.
Currently there is no skip buttons/icons for within track skip/control.
______________________________________________________________________________
SKIP 5secs & 1min HotKey Options:
Adding the << & >> skip within track as suggested here, would bring the usual expected functions to MusicBee, if not all the above goodies, at least the basics.
But this is a major feature change. Only the dev knows how much work it involves.
Adding the options to skip back/forth 15 seconds and 30 seconds in HotKeys, should be fairly easy to implement.
Because for podcasts/audio books when skip back/forth is often used with keyboard shortcuts, 5 seconds is too short and 1 minute is too long.
These skip shortcuts are the most used by people listening to spoken audio files, as opposed to music, as many of us know.
Thanks again.
Last Edit: January 12, 2019, 01:09:53 AM by washere
probably this plugin:
https://getmusicbee.com/forum/index.php?topic=27654.0
could evolve in future to satisfy these requests (it should be very easy for developer).
For the next v3.4 update I have added hotkeys for skip forward/back 20 seconds
rudolph
I think there is a bug.  It works when streamed audio (podcast) is paused, but can't rewind forward or back while streamed audio is playing.
I have put in some handling for web streams
