Author Topic: File Integrity Verifier  (Read 1838 times)
musicbeefan99
The only reason I have Foobar2000 installed still is to use this one plugin https://www.foobar2000.org/components/view/foo_verifier
Sometimes I'd be listening to a song in MusicBee and the song would randomly stop. So I'd open Foobar2000 and run that trusty FLAC Verifier plugin and it always detected the corrupt tracks 100% of the time.
If this was ported to MusicBee, like in the 'Tools' section, I would finally be able to get rid of Foobar2000. MusicBee is so amazing but it's just missing this one invaluable tool.
If there is a stand-alone FLAC verifier, you could install it and invoke it from the Tools menu. You need to set it up in Preferences > Tools > external application.
musicbeefan99
I don't know of any recent stand-alone FLAC verifiers like the Foobar one. The idea was to have it implemented in the program.
AudioTester 1.7 is a stand-alone that will test FLAC's for file integrity:  http://www.vuplayer.com/files/audiotester.zip .  Phred's suggestion will square you away.
urfausto
amazing, i was also keeping foobar with this only reason. thanks for the solution, i can drop foobar completely.  :)
