Author Topic: Bizarre behavior with auto playlists  (Read 61 times)
Scuttle
Version 3.2.6902
I have about 20 auto-playlists with a bunch of different music, different categories and different artists.
When I in the left sidebar double-click on one of the playlists, I expect Musicbee to start playing a random song from that playlist and then after that play another random song from that auto-playlist, and so on.
This does not happen. When I double-click an auto-playlists nothing happens.
Except.
If I first play an individual song from an auto-playlist by double-clicking on the songtitle in the main window and then double-click on the auto-playlist in the left sidebar, that same song plays.
If I double-click on another auto-playlist that contains that song, that song plays, but nothing else.
If I double-click on a second songtitle, that song plays. If I double-click on a auto-playlist containing these two song, one of the two will play, but none of the other songs in the playlist.
What. Is. Going. On?!
Last Edit: January 03, 2019, 01:31:39 PM by Scuttle
If you doing this via the navigator panel then i can reproduce the issue. It should be fine from the Playlist Explorer tab though.
This should fix the issue:
