Author Topic: [SOLVED]No album Cover art  (Read 1862 times)
mikl
Hi
My album cover art are disappear (in playlist on first song of album and in explorer all album cover art are disappear)
version 3.3.6940
Last Edit: January 03, 2019, 11:33:48 AM by mikl
Nobody can help you unless you supply more information.  For example:  when did the problem first start and after what operation;  was/is the artwork embedded or pointed at an image file;  what are your settings in Prefs/Tags (1)/Artwork storage; what appears when you right-click a file and choose edit and then artwork tab;  does the artwork show up when the file is looked at in an external tag editor like Kid3 or Mp3tag;  --etc.
mikl
problem appear after update to beta 3.3, in tag editor cover is present, in other tag editor tag is present.
No change of config from 3.2
screenshot : https://1drv.ms/u/s!AvmpLTEOutLOyzAFIJ-ERr9BkzCk
config : https://1drv.ms/u/s!AvmpLTEOutLOyzGpaGweEPYKgkJA
Problem solved
After few rescan all cover are present now
Last Edit: January 03, 2019, 11:33:22 AM by mikl
