Author Topic: Lyrics for Singalongs  (Read 771 times)
RAS11
I am trying to figure out a way to display song lyrics synchronized full screen to use for singalongs.  Is there a way to do this?
Freddy Barker
  • 🎧 MB 3.4.7628P
You can use MiniLyrics, see here:-
https://getmusicbee.com/addons/plugins/135/minilyrics-helper/
It may not be the most elegant solution, but if your Now Playing screen is set to have the lyrics displayed in the right "Now Playing Sidebar," you can simply drag the border of this sidebar to the left until it takes up the entire screen.
The best solution might be dedicated karaoke software, though.
RAS11
Thank you so much for the prompt replies.  This software is really great!  I tried several other apps before getting this one and I am glad I kept looking.
