Author Topic: Anima  (Read 12361 times)
A light skin with the player controls on the right side
download Anima
Note:
Be sure to disable 'Auto-Pick Panel Colours' if you want the player panel to look like the above screenshot.
If you have it enabled—which I believe is now the default—you will have a more bland-looking panel like this:
Last Edit: June 11, 2022, 10:07:30 AM by hiccup
A couple of oversights were fixed.
natswat
Updated, minor tweaks, device icons added.
(these device icons will only show up in MusicBee v3.4> which is not yet available at this moment)
Updated; the wavebar was slightly off-center.
updated
Main changes:
- The Jukebox view is skinned.
- The readability/contrast of sub-text fields in 'Album and Tracks' view and in the Expanded Album panel is improved.
note: both these updates only function under MusicBee 3.4
(which is currently under development and in alpha release state)
updated
improved the contrast/legibility of the text in the status bar
updated
The last.fm scrobble button can now be hidden.
Some other tweaks.
