Author Topic: Bose SoundTouch Music System IV  (Read 1906 times)
giannit
Will Bose SoundTouch Music System IV be able to read the MusicBee library? :'(
Does it communicate via DLNA or UPnP?  If so, MusicBee has a plugin that will offer your library over those protocols.
Except that the plugin frankz has referenced is no longer supported. I does work for some users. But it also doesn't work for others. So if your Bose can use DLNA, then it's worth a shot trying with this plugin.
