Hello,
I'm sorry to be making another post about this but only one problem was solved (which I appreciate) but the other question/problem remained unresolved.
Sometime in the last couple versions the volume slider turned into a number in the right panel controls. The main controls (which I usually have disabled) are fine, you can see in screenshot below, but I cannot for the life of me figure out how to get the slider back for the right panel.
I'm not sure if this is a bug, a deliberate change, or something else?
Thank you
