Author Topic: Autoplaylist filter  (Read 1010 times)
Aphotic
Greetings from Persia Bees
how to filter long/time-based tracks like i wanna add 1000 most listened tracks as auto-playlist but it also counts all my podcasts like how to match a rule so it filters out all mp3tracks longer than 30min for example?
or if u have a better idea tell me, i just wanna listen to my music no podcasts or long tracks.
screenshot:
http://s8.picofile.com/file/8345753326/photo_2018_12_15_00_46_02.jpg
thanks
Last Edit: December 14, 2018, 09:24:11 PM by Aphotic
gaar
I only took a quick look at your screenshot, and haven't tried it myself, but perhaps changing your parameter to time IS LESS THAN 30 minutes. That should only add tracks of 29 minutes or less to your auto-playlist.
Aphotic
thanks for quick reply i added time is less than 1200seconds & i think its done
but now another thing unrelated kinda:
screenshot
http://s9.picofile.com/file/8345756726/photo_2018_12_15_01_40_53.jpg
why do i always have 12 tracks with an error on top of my list?
what do i need to do to fix it?
gaar
Have you tried running Tools-->Locate Missing Files?
Aphotic
nicely done, but why does that happen? if i change the place of the folder slightly dsnt the library auto update and find it?
gaar
That depends on how you move the files/folders. If you move them via the Computer Node within MB, then it's easy for MB to keep track of where they were and where they are. If you're using a file manager outside of MB, it really can't be expect to know you've moved files. Unless you go through the extra step that svekul mentioned.
