Author Topic: Player don't see date added files  (Read 926 times)
koldek
Hi everyone,
I have a problem. The player don't see "date added" my recently added files.
With others older files the player sees "date added".
What can I do?
You can add "date added" column to the main panel to check what "date added" value was assigned to each track.
If they have no dated add value, that means they are not imported to your library.
koldek
The player always showed the date added of each file after entering the given folder. Bug is since I updated the program.
