Author Topic: bigger search box or even a search window  (Read 1363 times)
wobbly
i dont know if this is already in mb  if so cant find it
can you have a bigger search box or even a search window wen you click the search icon  like a popout screen  the search bar i have atm is too small thx
You can 'grab' the left side of the search box and drag it to the left and make it larger. In addition, you can type as much as you want/need into the existing search box. The text will scroll left as you fill up the box.
wobbly
i know how to make it longer . longer  is not bigger  font is still the same size i would  like a popout screen that has all search options
CTRL+F brings up a search dialogue.  Only searches entire library, not current node, though, as near as I can tell.
