EDIT: I just realized I'm using an older version of Musicbee. I was under the assumption I updated it recently, but apparantly not. *facepalm* I'll check the new version out now and will report back.EDIT2: updated Musicbee, both issues still persist. Updated the error message below.
I've got two bugs.
Both are in the happening in the 'Set Displayed Fields' window of the the Album and Tracks view.
Bug 1) I can't remove the Album column. I'm trying to drag it away, but it just stays where it is. I was wondering if it was working at all so I tried to drag other fields away which worked until...
Bug 2) I tried to drag Artwork away. Then a message popped up saying I can't remove Artwork in the Album and Tracks view. That's fine, that's logical, I didn't want to remove it anyway. But, when I click OK on the popup message, an error pops up:
MusicBee v3.2.6902.32258 (Win10.0), 8 dec 2018 11:34:
System.ObjectDisposedException: Geen toegang tot een verwijderd object.
Objectnaam: #=zTghIRFD2xAca.
bij System.Windows.Forms.Control.CreateHandle()
bij System.Windows.Forms.Control.get_Handle()
bij System.Windows.Forms.Control.PointToClientInternal(Point p)
bij #=zCNx3yFx_BUe5JY4PuqRGsU4=.#=zTghIRFD2xAca.#=zhS4XbEN2YxGX(MouseEventArgs #=z$KSsGfQ=)
bij #=zg1im_KvGVXKRBuLoTEGt5pU=.#=zPnlLYme$jChi.OnMouseMove(MouseEventArgs #=z$KSsGfQ=)
bij System.Windows.Forms.Control.WmMouseMove(Message& m)
bij System.Windows.Forms.Control.WndProc(Message& m)
bij #=zFxeYQ0HSC3TKwmc1oLYDnxg=.WndProc(Message& #=z69xdAPc=)
bij System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
bij System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
bij System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
