Author Topic: Musicbee + OBS  (Read 2491 times)
Knightmare
Is there any way to load a playlist from Musicbee into OBS? I know that OBS has a way to import from a .playlist file, but I don't think Musicbee can export as a file like that. I know about the plugin to display the information about what's playing now on the screen but the features for that seem limited. I was looking for something that has it's own banner and would display the songs as they play. Basically, I'm looking for some sort of widget that would be a thin banner that I could put at the bottom of my screen. I suppose too this might be a question for the developers of OBS, but even if they were to consider adding that feature, would it be possible?
Knightmare
I found what I was looking for. I just use the floating window and that seems to do the trick. Is there a way to set the floating window to be in the background, or at least have it only pop up when I want to use it?
