Author Topic: Move music to new HD, keep playlists etc...  (Read 1059 times)
HAL Lives
Hello All
I need to move my music files to a new, larger drive, but without losing my playlists.
I initially looked at the Send to / Folder (Move) command but that only seems to work on individual files, and not folders.
I copied my music to the new drive and assumed there would be a simple option to point MB at the new location, but if there is I can't find it.
My PC is Win7 Pro with the latest patches etc, my MB is v3.1.6950.
Hope you can help!
Paul
File->Library->Relink Music Paths
Assuming the structure is the same other than the drive letter (using X as old and Y as new as an example)
map music file path from: X:\
to: Y:\
If you the changes go deeper, give more detail.  For example, if on the old drive it was X:\Music and on the new drive it's Y:\MyMusic
map music file path from: X:\Music\
to: Y:\MyMusic\
Keep going to deeper levels until you get to where it's exactly the same for old and new.
HAL Lives
Thanks Frankz, that worked perfectly!  :)
I added a new file to the new drive, then imported it to my library/playlist and everything works exactly the way it should.
