Author Topic: 3.3 Skin Issues  (Read 2155 times)
gpzbc
When I installed the first beta for 3.3, I immediately started seeing weird skinning issues. No matter what skin I choose, it appears the same. It's as if it has a marble background. Am I missing something? Any help would be greatly appreciated. Thank you!
Here is a screenshot.
Screenshot
I know there's a feature now to let you use a background image. I don't know the details of how it works, though. Check your skins  folder maybe?
gpzbc:  the option psychoadept refers to is in Prefs-->Layout (1)-->general-->background (select).  Check to be sure the browse box under that isn't pointed at some image with the marbling.  From your screenshot, it certainly looks like this is what's happening.
gpzbc
Yes, that worked. I'm not sure how that got turned on? Anyways, I unchecked the background image option and everything is good now. Thank you to both of you. I appreciate it.
