Author Topic: Locking Playlists?  (Read 1602 times)
chrisdivine
HI!
Do U know, if there is a way 2 lock a certain playlist 2 protect it against unintended change.
Thanks 4 an answer!
I assume you're talking about static playlists, correct? And not auto-playlists since a lock on auto-playlists would defeat their purpose.
But no such option currently exists. If it's important to you, post it to the Wishlist sub-forum for possible consideration.
Freddy Barker
  • 🎧 MB 3.4.7628P
HI!
Thanks 4 an answer!
Maybe you could make the static playlist(s) 'read only' or just keep regular (working ok) backups?
I don't see this as a worthwhile item for the Wishlist, although I could be wrong  ;D
Last Edit: November 27, 2018, 02:38:38 PM by Freddy Barker
I'd support a wishlist request. Making it read only might work, would have to try it and see if MusicBee squawks.
Freddy Barker
  • 🎧 MB 3.4.7628P
Haha! - or buzzes, parrots squawk  ;)
chrisdivine
Thanks 4 your answers, I will post this topic on the wishlist!
