Author Topic: highlighted selected text does not change color  (Read 685 times)
Antonio
Setting a highlighting rule to color the text is a nice feature.
But I noticed that when text is colored because of such a rule and you select a track, the text color remains the same.
I have tried a couple of skins and for some the background will change a bit but it is hard to know if you have selected a track because the text color stays the same.
Should the text color of a highlighted track be overruled when you select it?
Is this depending on the skin?
