Author Topic: "More Albums" artist information broken- iTunes request error?  (Read 2055 times)
EastFeast
Hi, I just started using Musicbee today, so my settings are mostly stock and I haven't installed any plugins yet.
When I am in the Music explorer, the "More Albums" tab under Artist Information is broken. The message is:
Unable to retrieve the data from the iTunes Store
<html><head><title>Error</title></head><body>Your request produced an error.<BR>[newNullResponse]</body></html>
I am still able to access the [iTunes page] for this artist from my browser:
This bug happens for all artists.
The issue is with iTunes store api. If its still doing it after a few days, let me know and I can make a change so it works again
dayter
Hi, The issue with iTunes store api is still there, tested it with 2 PC's :-(
ocram35
Hi Steven
I second the issue. It is quite new, as I use this feature about twice a week, and use Musicbee practically daily. It worked a week ago, I am sure of that.
It is very nice to have all this context, I think this is a very distinctive feature and if you can make it work again this would be great.
All the best
i am going to leave this a few days and if the store API is not fixed then i will make a change to address the issue.
here is a v3.2 patch version that works:
https://getmusicbee.com/patches/MusicBee32_Patched.zip
the next v3.3 patch when its ready will also contain the fix
