Author Topic: right panel artwork resizing  (Read 1322 times)
tmprojection
hey guys, whenever i resize the right panel width, the artwork gets hidden:
https://gyazo.com/b13a0fa8adfd5874a32add24496a4bf7
i have to click and drag the top of the artwork manually each time for it to fit
is there any way to set it up so that the artwork gets resized snapped to the bottom right corner, rather than it being repositionable by height
if you are using the album cover element then dock it at the top of the panel and it should shift the playing tracks panel down
tmprojection
not sure how to do that, this is my settings:
https://gyazo.com/612c08dae027eaa289a77fa5b836e780
sorry could you explain a little please, thank you so much :)
tmprojection
could you clarify for me when you have the time please, :) thanks a lot, really appreciate the work you are doing
What he meant was to move album cover element to the top of the sidebar using panel arrangement dialog (View> Arrange Panels).
tmprojection
figured it out, i had my album cover displayed through now playing track information, rather than a seperate element, sorry about that
