I have an LG V20 phone running Android Oreo (8.0.0) and have the latest version of MB running on my system. When I choose playlists in the Sync settings, it copies them over fine. If I go to a specific album and right click on it, go to Send To and then Device V20, it ends it over fine. However, if I go to my playlists tab and right click a specific playlist, go to Send To and then Device V20, nothing happens. It never sends the files to the phone.
Is there something I should be doing when it comes to the playlists? I don't want to set up auto-sync, at least not till I have everything the way I want it, so I'm just manually sending files to my phone, and I find it odd that everything else works, including manual syncing of albums, just not playlists.
Thank you in advance for any help!
