Author Topic: Docking the Playlist with Playing Tracks  (Read 1433 times)
raitken
Would it be possible to move the playlist location to the right hand side, similar to how iTunes 8 had it?
This made it easier to see playlists at a glance and drag songs into them:
I have done a mock up on how I'd like it to be dispalyed (highlighted in red):
How it looks at the moment:
+1, seems like this would be easy to implement for the playlist directory panel
you can now dock the playlist explorer in the right panels
