Author Topic: Sync should be brought into MusicBee  (Read 1034 times)
Samiran
The settings and layout configuration should be synced, it would be very helpful for users to sync those settings into the cloud realtime, in case of system crash the entire MusicBee settings & layout can be restored very conveniently by simply logging in to the user account.
Freddy Barker
  • 🎧 MB 3.4.7628P
Alternatively,  you could use a program like Synctoy or FreeFileSync to do the copy to your cloud of chioce, after you have made changes and everything is working OK?
If it was done automatically, it could then copy an unwanted result or a possible error as well!
Best regards; Freddy
Last Edit: November 04, 2018, 05:28:13 PM by Freddy Barker
